Ana içeriğe geç
Headphone Jack
Neye ihtiyacın var
  1. Headphone Jack, Battery: adım 1, 1 resimden 1.
    • Unplug laptop from adapter and all other devices.
  2. Headphone Jack: adım 2, 1 resimden 1.
    • Flip the laptop over with battery facing you.
  3. Headphone Jack: adım 3, 2 resimden 1. Headphone Jack: adım 3, 2 resimden 2.
    • Slide the battery lock on the right side open.
    • Slide the Battery release latch on the left side.
  4. Headphone Jack: adım 4, 1 resimden 1.
    • Pull battery out.
  5. Headphone Jack, Keyboard: adım 5, 1 resimden 1.
    • Remove the two 6.5mm Phillips #1 keyboard screws from bottom of laptop.
  6. Headphone Jack: adım 6, 1 resimden 1.
    • Push screwdriver through screw hole top pop the keyboard.
    • Make sure the screen is open.
  7. Headphone Jack: adım 7, 1 resimden 1.
    • Pry up the keyboard.
    • The keyboard is still attached by it's ribbon.
  8. Headphone Jack: adım 8, 1 resimden 1.
    • Remove keyboard wire by popping latch under blue plastic
  9. Headphone Jack, Case: adım 9, 1 resimden 1.
    • Using the spudger to lift up on the white tabs
    • Pull horizontally on the blue ribbon to disconnect the cables
  10. Headphone Jack: adım 10, 1 resimden 1.
    • Remove the five 5.5mm Phillips #1 screws from the case
  11. Headphone Jack: adım 11, 1 resimden 1.
    • Remove eight 6.5mm Phillips #1 screws from the back cover
  12. Headphone Jack: adım 12, 3 resimden 1. Headphone Jack: adım 12, 3 resimden 2. Headphone Jack: adım 12, 3 resimden 3.
    • Starting at a top corner, use the pry tool to split the case.
    • Slowly work around the case, pulling up gently to release the clips.
  13. Headphone Jack, Headphone Jack: adım 13, 1 resimden 1.
    • Use the spudger to lift the white tab
    • pull horizontally on the blue ribbon to disconnect the cable
  14. Headphone Jack: adım 14, 1 resimden 1.
    • Use plastic pry tool to lift up on headphone jack assembly
Sonuç
Tyler Lirio
93 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S11-G2, Cheng Spring 2018 USF Tampa, Team S11-G2, Cheng Spring 2018 üyesi
USFT-CHENG-S18S11G2
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 191
