Ana içeriğe geç
Health o Meter HDR743 Power Supply Replacement
Neye ihtiyacın var
  1. Health o Meter HDR743  Power Supply Replacement, Power Supply: adım 1, 1 resimden 1.
    • Connect a voltmeter at the power supply’s connection to the circuit board and the power supply.
    • If the the voltage at the power supply is incorrect, the power supply should be replaced.
  2. Health o Meter HDR743  Power Supply Replacement: adım 2, 1 resimden 1.
    • Use wire strippers to cut the wired connection to the power supply.
    • If the wires need replacing, you will need to use a soldering iron and remove the connections at the board.
  3. Health o Meter HDR743  Power Supply Replacement: adım 3, 1 resimden 1.
    • Use the wire strippers to cut off the rubber ends of the power supply wires.
    • Use a soldering iron and solder to fuse the connections between the two wires.
  4. Health o Meter HDR743  Power Supply Replacement: adım 4, 2 resimden 1. Health o Meter HDR743  Power Supply Replacement: adım 4, 2 resimden 2.
    • Test the power supply once the wires have been reconnected.
    • If the Health o Meter still has power issues, check the connections between the new power supply and the board.
    • If no issues are found, the circuit board may need to be replaced.
Sonuç
Dennis White Jr
217 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 128
