Ana içeriğe geç
Heating Element Contacts
Neye ihtiyacın var
    1. Heating Element Contacts, Heating Element Contacts: adım 1, 3 resimden 1. Heating Element Contacts, Heating Element Contacts: adım 1, 3 resimden 2. Heating Element Contacts, Heating Element Contacts: adım 1, 3 resimden 3.
      • Before you begin, be sure to unplug your coffee maker.
      • Flip the coffee maker over so the bottom is facing upwards.
      • Use the T10 Torx screwdriver to remove all four 17 mm-long screws.
      • Lift the bottom cover off the bottom of the coffee maker.
      FixBot'a Sor
      Yorum Ekle
    2. Heating Element Contacts: adım 2, 2 resimden 1. Heating Element Contacts: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      FixHub Smart Soldering Iron
      $79.95
      • If heating element contacts are disconnected, use soldering iron with soldering wire to re-bond the contacts.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Austin Wheaton
903 İtibar
4 adet Kılavuz yazıldı
Ekip
UW Stout, Team S8-G1, Ogden Spring 2018 UW Stout, Team S8-G1, Ogden Spring 2018 üyesi
UWSTOUT-OGDEN-S18S8G1
4 Üyeler
20 adet Kılavuz yazıldı
1Rehber Yorum
Cuisinart Drip Coffee Maker:
Model CBC-6500PCC
In use:
Less than one year.
Problem:
Not heating
Cause:
Blown thermal fuse (240C) connected in series with one side of heating element (there are two, each one connected in series and attached directly to each side of the heating element.) Not replaceable by itself.
Remedy:
Replacement under warranty or purchase a used one at Goodwill, Salvation Army, Value Village, local online personal seller, etc.
brian.steven.richmond - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 62
Her zaman: 4,102
