Ana içeriğe geç
Hello Zee Smart Core Front Case Replacement
Neye ihtiyacın var
  1. Hello Zee Smart Core Front Case Replacement, Front Case: adım 1, 2 resimden 1. Hello Zee Smart Core Front Case Replacement, Front Case: adım 1, 2 resimden 2.
    • This model is 64GB
  2. Hello Zee Smart Core Front Case Replacement, Opening: adım 2, 3 resimden 1. Hello Zee Smart Core Front Case Replacement, Opening: adım 2, 3 resimden 2. Hello Zee Smart Core Front Case Replacement, Opening: adım 2, 3 resimden 3.
    • Insert the spudger into a corner and separate the halves
    • Do not puncture the battery
  3. Hello Zee Smart Core Front Case Replacement, Main board unmounting: adım 3, 2 resimden 1. Hello Zee Smart Core Front Case Replacement, Main board unmounting: adım 3, 2 resimden 2.
    • Use your spudger’s pointed tip to unscrew the screws
  4. Hello Zee Smart Core Front Case Replacement, Board removal: adım 4, 2 resimden 1. Hello Zee Smart Core Front Case Replacement, Board removal: adım 4, 2 resimden 2.
    • Use your spudger to pry up the board from the sides
    • Do not break it
    • Do not pry from the battery side
  5. Hello Zee Smart Core Front Case Replacement, Electronics removal: adım 5, 3 resimden 1. Hello Zee Smart Core Front Case Replacement, Electronics removal: adım 5, 3 resimden 2. Hello Zee Smart Core Front Case Replacement, Electronics removal: adım 5, 3 resimden 3.
    • CAREFULLY pry under the battery to remove it
    • there are no permanent adhesives, though there may be sticky tape
    • Spectate everything from the case
Sonuç
To reassemble your device, follow these instructions in reverse order, using your replacement case instead of the one described.
Bir başkası bu kılavuzu tamamladı.
9021007
4.656 İtibar
25 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 675
