Giriş
Overly long pants will bunch up at the ankles, and may even drag along the ground or get caught under your shoes. (If you thought last season's styles were embarrassing, try tripping over your own pants.) Use this guide to avoid fashion faux pas by hemming your pants to suit.
For replacement parts or further assistance, contact Patagonia Customer Service.
Neye ihtiyacın var
Begin by assessing the pants' current length. This is best done by wearing the pants along with an appropriate pair of shoes.
Fold the cuff of one pant leg inward, and adjust it to the desired length.
Insert two or three pins to hold the cuff in position.
The pins should be placed parallel to the new fold.
With the pins in place, verify that the length is correct.
Make any final adjustments to the length as needed.
On a flat, clean surface, lay the pants down on their side with the newly shortened pant leg on top.
Using a ruler, note the distance from the edge of the old cuff to the edge of the new cuff.
Repeat the measurement several times along the width of the cuff, making sure the new hemline is perfectly even.
Repeat steps 5-19 for the second pant leg.
6 farklı kişi bu kılavuzu tamamladı.
