Giriş
If the high-low switch no longer works either the switch or PCB needs replacing.
If the motor powers up for a second when turns off and then dies it can also be a problem with the PCB.
The PCBs for Henrys can be expensive and hard to source but it can be easily bypassed. This will remove the high-low function but it will still work.
Neye ihtiyacın var
Videoya Genel Bakış
Make sure it unplugged from the mains.
Pull out the black clips on each side of the head.
Remove the 4 outer Phillips screws
Remove the cable reel from the top
Pull the PCB out of its slot inside the housing
Remove all of the wires from the PCB
Remove the 2 wires from the on-off switch which connected to the rest of the vacuum cleaner.
Connect the 2 white wires from the motor to the green on-off switch.
Place the red high-low switch back in to its holder in the casing to fill the gap and prevent potential shocks.
Optionally, an indicator LED can be purchased online to fill the gap.
