Ana içeriğe geç
Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement
Neye ihtiyacın var
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Ear-pad Cushion: adım 1, 2 resimden 1. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Ear-pad Cushion: adım 1, 2 resimden 2.
    • Position the headphones so that you can see the opening for the cushion as you take out your blue iFixIt opening tool. In between the earpad cushion and the headset, place the iFixit opening tool.
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: adım 2, 1 resimden 1.
    • The connectors that the cushion snaps into place are used to attach the cushion to the headset. The connectors could be damaged by applying too much force, which would prevent the cushion from returning to its original position.
  3. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: adım 3, 1 resimden 1.
    • After the earpad cushion has been disconnected from the connectors you can take your new earpad cushion and install it.
  4. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Battery: adım 4, 2 resimden 1. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement, Battery: adım 4, 2 resimden 2.
    • After removing the ear pad cushion, unscrew the four 1.6mm black screws with your Phillips-head screwdriver.
  5. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: adım 5, 2 resimden 1. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: adım 5, 2 resimden 2.
    • Use the Phillips-head screwdriver to remove the black casing screws.
    • Lift the casing to see the battery.
  6. Heyday Active Noise-Canceling Wireless Headphones 0398 Battery Replacement: adım 6, 1 resimden 1.
    • The central spherical piece of metal is the battery. Use the ifixit opening tool and pry open the battery in your direction to remove the battery.
Sonuç
Christopher Puperi
493 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 118
