Ana içeriğe geç
Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement
Neye ihtiyacın var
  1. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement, Headband: adım 1, 2 resimden 1. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement, Headband: adım 1, 2 resimden 2.
    • With the opening tool, pry the plastic tabs that hold the headband to the headphones outward. Remove the plastic tab on both sides of the headband..
  2. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement: adım 2, 2 resimden 1. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement: adım 2, 2 resimden 2.
    • The headband itself is held in by four 1.2mm screws where the tabs were. Remove the screws with 00 Phillips screwdriver.
  3. Heyday Active Noise-Canceling Wireless Headphones 0398 Headband Replacement: adım 3, 1 resimden 1.
    • Push outward and in your direction with the opening tool to separate the headband from the headphones. Replace by following the directions backwards.
Sonuç
Christopher Puperi
493 İtibar
5 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 64
