Ana içeriğe geç
Heyday Suitcase Turntable Belt Replacement
Neye ihtiyacın var
  1. Heyday Suitcase Turntable Belt Replacement, Platter: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    $3.99
    • Unlock the front latches and open the turntable suitcase cover.
    • Using angled tweezers or a Halberd spudger, pry the spindle shaft from the spindle.
    • Be careful, as the spindle shaft may fly off in an unexpected direction.
    FixBot'a Sor
    Yorum Ekle
  2. Heyday Suitcase Turntable Belt Replacement: adım 2, 1 resimden 1.
    • Use both hands to gently lift the platter up and off of the turntable.
    FixBot'a Sor
    Yorum Ekle
  3. Heyday Suitcase Turntable Belt Replacement, Belt: adım 3, 1 resimden 1.
    • Flip the platter over.
    • Pull the belt off from the edge of the platter.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. After removing the old belt, replace it by attaching the new belt around the platter. Then, put the platter and the spindle shaft back to its original place. Feel free to refer to the platter replacement guide if necessary.
Caroline D'Amato
565 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Petersen Fall 2022 UMass Dartmouth, Team 2-1, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S2G1
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 38
Her zaman: 881
