Giriş
If you need to replace the belt of your Heyday Suitcase Turntable, follow this repair guide.
The belt rotates the platter of a record player's turntable. If the turntable is spinning at an inconsistent speed, replacing the belt can help. The Heyday Suitcase Turntable uses a 40cm/15.75in belt.
Before beginning the repair, turn off the turntable and unplug the power cord from the device.
Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$3.99
Using angled tweezers or a Halberd spudger, pry the spindle shaft from the spindle.
To reassemble your device, follow these instructions in reverse order. After removing the old belt, replace it by attaching the new belt around the platter. Then, put the platter and the spindle shaft back to its original place. Feel free to refer to the platter replacement guide if necessary.
