Giriş
Follow this repair guide if you need to replace the lever of your Heyday Suitcase Turntable.
If the tonearm does not raise or lower, the lever likely needs to be replaced.
Before beginning this repair, turn off the record player and unplug the power cord.
Neye ihtiyacın var
Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
Use a Phillips #2 screwdriver to remove the screw securing the plate that covers the lever.
Remove the plate blocking access to the lever.
