Ana içeriğe geç
Heyday Suitcase Turntable Lever Replacement
Neye ihtiyacın var
  1. Heyday Suitcase Turntable Lever Replacement, Baseboard: adım 1, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
  2. Heyday Suitcase Turntable Lever Replacement: adım 2, 1 resimden 1.
    • Use a metal spudger to pry the baseboard off of the case.
    • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
  3. Heyday Suitcase Turntable Lever Replacement: adım 3, 2 resimden 1. Heyday Suitcase Turntable Lever Replacement: adım 3, 2 resimden 2.
    • Disconnect the cords from the circuit board.
    • Take a picture beforehand so it's easier to put them back during reassembly.
    • Remove the baseboard.
  4. Heyday Suitcase Turntable Lever Replacement, Lever: adım 4, 2 resimden 1. Heyday Suitcase Turntable Lever Replacement, Lever: adım 4, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove the screw securing the plate that covers the lever.
    • Remove the plate blocking access to the lever.
  5. Heyday Suitcase Turntable Lever Replacement: adım 5, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the plate securing the lever.
  6. Heyday Suitcase Turntable Lever Replacement: adım 6, 1 resimden 1.
    • Pull the lever out of the front of the device.
Sonuç
Caroline D'Amato
565 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Petersen Fall 2022 UMass Dartmouth, Team 2-1, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S2G1
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 161
