Ana içeriğe geç
Heyday Suitcase Turntable Motor Replacement
Neye ihtiyacın var
  1. Heyday Suitcase Turntable Motor Replacement, Platter: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    $3.99
    • Unlock the front latches and open the turntable suitcase cover.
    • Using angled tweezers or a Halberd spudger, pry the spindle shaft from the spindle.
    • Be careful, as the spindle shaft may fly off in an unexpected direction.
    FixBot'a Sor
    Yorum Ekle
  2. Heyday Suitcase Turntable Motor Replacement: adım 2, 1 resimden 1.
    • Use both hands to gently lift the platter up and off of the turntable.
    FixBot'a Sor
    Yorum Ekle
  3. Heyday Suitcase Turntable Motor Replacement, Baseboard: adım 3, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
    FixBot'a Sor
    Yorum Ekle
  4. Heyday Suitcase Turntable Motor Replacement: adım 4, 1 resimden 1.
    • Use a metal spudger to pry the baseboard off of the case.
    • Be cautious of the cords and circuit located underneath the knob and the lever. Don't pull or yank the baseboard off.
    FixBot'a Sor
    Yorum Ekle
  5. Heyday Suitcase Turntable Motor Replacement: adım 5, 2 resimden 1. Heyday Suitcase Turntable Motor Replacement: adım 5, 2 resimden 2.
    • Disconnect the cords from the circuit board.
    • Take a picture beforehand so it's easier to put them back during reassembly.
    • Remove the baseboard.
    FixBot'a Sor
    Yorum Ekle
  6. Heyday Suitcase Turntable Motor Replacement, Motor: adım 6, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the screws connecting the motor and the baseboard.
    • The motor is located underneath the platter.
    FixBot'a Sor
    Yorum Ekle
  7. Heyday Suitcase Turntable Motor Replacement: adım 7, 1 resimden 1.
    • Flip the baseboard over.
    • Unplug the cable connecting the motor to the baseboard.
    • Remove the motor.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Caroline D'Amato
565 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-1, Petersen Fall 2022 UMass Dartmouth, Team 2-1, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S2G1
4 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 667
