Ana içeriğe geç
High Heel Buckle Replacement
Neye ihtiyacın var
  1. High Heel Buckle Replacement, Elastic Strap Buckle: adım 1, 3 resimden 1. High Heel Buckle Replacement, Elastic Strap Buckle: adım 1, 3 resimden 2. High Heel Buckle Replacement, Elastic Strap Buckle: adım 1, 3 resimden 3.
    • Cut through the remaining thread of the elastic strap.
    • Remove the strap buckle to adjust the position.
    • This step is only if the elastic strap is still attached by any little thread. If the buckle is already detached, skip to step two.
  2. High Heel Buckle Replacement: adım 2, 2 resimden 1. High Heel Buckle Replacement: adım 2, 2 resimden 2.
    • Slide the end of the strap underneath the buckle frame without the center prong.
  3. High Heel Buckle Replacement: adım 3, 2 resimden 1. High Heel Buckle Replacement: adım 3, 2 resimden 2.
    • Lift the center buckle prong vertically and place it into the center of the strap elastic.
  4. High Heel Buckle Replacement: adım 4, 1 resimden 1.
    • Continue pushing the strap elastic down underneath the other side buckle frame.
  5. High Heel Buckle Replacement: adım 5, 2 resimden 1. High Heel Buckle Replacement: adım 5, 2 resimden 2.
    • Fold the detached elastic strap together with the strap attached to the heel so that both straps are evenly lined up.
  6. High Heel Buckle Replacement: adım 6, 3 resimden 1. High Heel Buckle Replacement: adım 6, 3 resimden 2. High Heel Buckle Replacement: adım 6, 3 resimden 3.
    • With a threaded needle, sew along the ends of the straps in order to enclose the buckle in place.
    • Avoid poking your fingers with the needle.
  7. High Heel Buckle Replacement: adım 7, 2 resimden 1. High Heel Buckle Replacement: adım 7, 2 resimden 2.
    • Test out the buckle to ensure it is lined properly and can now strap the heel.
Bitiş Çizgisi
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 127
Son 30 gün: 342
Her zaman: 8,279
