Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
After years of service your battery may be weak or no longer hold a charge. This guide replaces your battery with a new one.
  1. Remove the two 3mm screws using a PH00 screwdriver.
    • Remove the two 3mm screws using a PH00 screwdriver.
  2. Use the blue plastic opening tool to gently pry the back case off.
    • Use the blue plastic opening tool to gently pry the back case off.
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. Disconnect the wires that connect the battery to the motherboard using the spudger.
    • Disconnect the wires that connect the battery to the motherboard using the spudger.
  5. Slide the spudger underneath the battery and gently lift it off of the adhesive.
    • Slide the spudger underneath the battery and gently lift it off of the adhesive.
  6. Place the new battery in the same location and connect the wires the same way as the previous battery. Place the new battery in the same location and connect the wires the same way as the previous battery.
    • Place the new battery in the same location and connect the wires the same way as the previous battery.
Sonuç
Brandon Snodgrass
410 İtibar
4 adet Kılavuz yazıldı
Takım
Clemson, Team 15-8, Shirley Winter 2015 Clemson, Team 15-8, Shirley Winter 2015 üyesi
CLEM-SHIRLEY-W15S15G8
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 658
