Ana içeriğe geç
Hipstreet Equinox 2 Motherboard Replacement
Neye ihtiyacın var
  1. Hipstreet Equinox 2 Motherboard Replacement, Rear Case: adım 1, 1 resimden 1.
    • Remove the two 3mm screws using a PH00 screwdriver.
  2. Hipstreet Equinox 2 Motherboard Replacement: adım 2, 1 resimden 1.
    • Use the blue plastic opening tool to gently pry the back case off.
  3. Hipstreet Equinox 2 Motherboard Replacement, Motherboard: adım 3, 1 resimden 1.
    • Unsolder these wires from the motherboard, it is a good idea to label these wires as you remove them according to the picture to the left.
  4. Hipstreet Equinox 2 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove contact strips by lifting gently on the clip indicated in this picture, then pulling strip out of the clip.
  5. Hipstreet Equinox 2 Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the 3.5mm screws located at these locations shown on the picture by using the PH00 screwdriver.
  6. Hipstreet Equinox 2 Motherboard Replacement: adım 6, 1 resimden 1.
    • Gently lift the motherboard out of the tablet, make sure no wires are still caught or attached while you lift the motherboard.
Sonuç
Brandon Snodgrass
410 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 15-8, Shirley Winter 2015 Clemson, Team 15-8, Shirley Winter 2015 üyesi
CLEM-SHIRLEY-W15S15G8
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 354
