Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
The speakers could have been broken by playing audio files that have been altered to excessive volume levels, or maybe they got wet and broke apart. This guide explains how to change them out.
  1. Remove the two 3mm screws using a PH00 screwdriver.
    • Remove the two 3mm screws using a PH00 screwdriver.
  2. Use the blue plastic opening tool to gently pry the back case off.
    • Use the blue plastic opening tool to gently pry the back case off.
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. Use a plastic opening tool to remove the speakers from the case.
    • Use a plastic opening tool to remove the speakers from the case.
    • Desolder the wires from the motherboard.
    • Be sure to note which wire, red or black, corresponds to which connection on the motherboard.
  5. Solder the wires of the new speaker to the motherboard as shown in the image.
    • Solder the wires of the new speaker to the motherboard as shown in the image.
  6. Glue the speakers flat against their respective sound output panels with the silver sides facing out/towards the interior of the tablet.
    • Glue the speakers flat against their respective sound output panels with the silver sides facing out/towards the interior of the tablet.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joel Miller
119 İtibar
1 Kılavuz yazıldı
Takım
Clemson, Team 15-8, Shirley Winter 2015 Clemson, Team 15-8, Shirley Winter 2015 üyesi
CLEM-SHIRLEY-W15S15G8
5 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 137
