Giriş
Once you have disassembled the tablet cover, you can now access all of the internal components. This is a simple process and will require a replacement camera to complete.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
Use your plastic opening tool to lift the black ribbon connector lock.
Then, proceed to remove the camera.
2 farklı kişi bu kılavuzu tamamladı.
