Ana içeriğe geç
Hipstreet Titan 2 HD Camera Replacement
Neye ihtiyacın var
  1. Hipstreet Titan 2 HD Camera Replacement, Rear Case: adım 1, 1 resimden 1.
    • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
    • The screws are located on the bottom face of the device, near the power and volume controls.
  2. Hipstreet Titan 2 HD Camera Replacement: adım 2, 1 resimden 1.
    • Place the small suction cup on your screen.
    • Moisturize the bottom of the suction cup to ensure a proper seal.
    • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
  3. Hipstreet Titan 2 HD Camera Replacement: adım 3, 1 resimden 1.
    • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
    • Grasp the small suction cup.
  4. Hipstreet Titan 2 HD Camera Replacement: adım 4, 2 resimden 1. Hipstreet Titan 2 HD Camera Replacement: adım 4, 2 resimden 2.
    • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
    • Pull upward on the small suction cup handle while sliding the opening tool.
    • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
  5. Hipstreet Titan 2 HD Camera Replacement: adım 5, 2 resimden 1. Hipstreet Titan 2 HD Camera Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to remove the speaker from the rear cover.
    • The speaker is held in place with adhesive and is easily removed.
    • Do not pull on the speaker wires. This could damage the soldering connections.
  6. Hipstreet Titan 2 HD Camera Replacement: adım 6, 1 resimden 1.
    • Once the speaker is disconnected, the cover removal is complete.
  7. Hipstreet Titan 2 HD Camera Replacement, Camera: adım 7, 2 resimden 1. Hipstreet Titan 2 HD Camera Replacement, Camera: adım 7, 2 resimden 2.
    • Use your plastic opening tool to lift the black ribbon connector lock.
    • Then, proceed to remove the camera.
  8. Hipstreet Titan 2 HD Camera Replacement: adım 8, 1 resimden 1.
    • Once the camera with the ribbon connector is removed, the process is complete.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jeffrey
766 İtibar
5 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 5-6, Panko Spring 2015 Colorado Springs, Team 5-6, Panko Spring 2015 üyesi
UCCS-PANKO-S15S5G6
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 7
Her zaman: 372
