Ana içeriğe geç
Hipstreet Titan 2 HD Rear Case Replacement
Neye ihtiyacın var
  1. Hipstreet Titan 2 HD Rear Case Replacement, Rear Case: adım 1, 1 resimden 1.
    • Using the PH#00 screwdriver, remove the two 0.145 inch Phillips head screws.
    • The screws are located on the bottom face of the device, near the power and volume controls.
  2. Hipstreet Titan 2 HD Rear Case Replacement: adım 2, 1 resimden 1.
    • Place the small suction cup on your screen.
    • Moisturize the bottom of the suction cup to ensure a proper seal.
    • If the screen is cracked, the suction cup may not seal correctly; too much pressure may crack or damage the screen.
  3. Hipstreet Titan 2 HD Rear Case Replacement: adım 3, 1 resimden 1.
    • Insert the plastic opening tool between the screen cover and rear cover of the tablet.
    • Grasp the small suction cup.
  4. Hipstreet Titan 2 HD Rear Case Replacement: adım 4, 2 resimden 1. Hipstreet Titan 2 HD Rear Case Replacement: adım 4, 2 resimden 2.
    • Slide the plastic opening tool along device edge to separate the screen cover from the rear cover.
    • Pull upward on the small suction cup handle while sliding the opening tool.
    • When sliding the plastic opening tool, avoid sliding the tool too far into the cover. This could damage the speaker connector on the back cover.
  5. Hipstreet Titan 2 HD Rear Case Replacement: adım 5, 2 resimden 1. Hipstreet Titan 2 HD Rear Case Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to remove the speaker from the rear cover.
    • The speaker is held in place with adhesive and is easily removed.
    • Do not pull on the speaker wires. This could damage the soldering connections.
  6. Hipstreet Titan 2 HD Rear Case Replacement: adım 6, 1 resimden 1.
    • Once the speaker is disconnected, the cover removal is complete.
Sonuç
Congratulations your tear down is complete. To reassemble your device, follow these instructions in reverse order.
Bir başkası bu kılavuzu tamamladı.
Jeffrey
766 İtibar
5 adet Kılavuz yazıldı
Ekip
Colorado Springs, Team 5-6, Panko Spring 2015 Colorado Springs, Team 5-6, Panko Spring 2015 üyesi
UCCS-PANKO-S15S5G6
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 640
