Giriş
This motherboard replacement guide will walk you through the steps on how to remove necessary components in order to get to the motherboard. Replacing the motherboard is a moderate, four-step process using necessary tools, including a soldering iron.
Neye ihtiyacın var
Use the plastic opening tools to pry the screen from the back of the device.
Bir başkası bu kılavuzu tamamladı.
