Ana içeriğe geç
Hisense Chromebook C11 Screen Replacement
Neye ihtiyacın var
  1. Hisense Chromebook C11 Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Turn off the laptop and disconnect it from power.
  2. Hisense Chromebook C11 Screen Replacement: adım 2, 3 resimden 1. Hisense Chromebook C11 Screen Replacement: adım 2, 3 resimden 2. Hisense Chromebook C11 Screen Replacement: adım 2, 3 resimden 3.
    • Snap the plastic holds off of the screen protector using the plastic opening tool.
  3. Hisense Chromebook C11 Screen Replacement: adım 3, 3 resimden 1. Hisense Chromebook C11 Screen Replacement: adım 3, 3 resimden 2. Hisense Chromebook C11 Screen Replacement: adım 3, 3 resimden 3.
    • Remove the screw caps.
  4. Hisense Chromebook C11 Screen Replacement: adım 4, 3 resimden 1. Hisense Chromebook C11 Screen Replacement: adım 4, 3 resimden 2. Hisense Chromebook C11 Screen Replacement: adım 4, 3 resimden 3.
    • Unscrew the screws with the Phillips #00 screwdriver and set them aside.
  5. Hisense Chromebook C11 Screen Replacement: adım 5, 3 resimden 1. Hisense Chromebook C11 Screen Replacement: adım 5, 3 resimden 2. Hisense Chromebook C11 Screen Replacement: adım 5, 3 resimden 3.
    • Remove the screen protector.
  6. Hisense Chromebook C11 Screen Replacement: adım 6, 2 resimden 1. Hisense Chromebook C11 Screen Replacement: adım 6, 2 resimden 2.
    • Unscrew the screen screws with the Phillips #000 screwdriver and set them aside. Be sure to support the screen protector in case it falls.
  7. Hisense Chromebook C11 Screen Replacement: adım 7, 2 resimden 1. Hisense Chromebook C11 Screen Replacement: adım 7, 2 resimden 2.
    • Gently lay the screen down.
  8. Hisense Chromebook C11 Screen Replacement: adım 8, 3 resimden 1. Hisense Chromebook C11 Screen Replacement: adım 8, 3 resimden 2. Hisense Chromebook C11 Screen Replacement: adım 8, 3 resimden 3.
    • Disconnect the screen.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Chelsea Charles
422 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Leahy Fall 2018 USF Tampa, Team S1-G3, Leahy Fall 2018 üyesi
USFT-LEAHY-F18S1G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 923
