Ana içeriğe geç
Hisense Chromebook C11 Trackpad Replacement
Neye ihtiyacın var
  1. Hisense Chromebook C11 Trackpad Replacement, Back Panel: adım 1, 1 resimden 1.
    • Remove the front two hub caps.
    • When finished, you should be able to remove the back cover.
  2. Hisense Chromebook C11 Trackpad Replacement: adım 2, 1 resimden 1.
    • Unscrew the screws with the Phillips #00 screwdriver.
  3. Hisense Chromebook C11 Trackpad Replacement: adım 3, 1 resimden 1.
    • Pry the perimeter of the case open with the plastic opening tool.
    • Remove the back panel.
  4. Hisense Chromebook C11 Trackpad Replacement, Trackpad: adım 4, 1 resimden 1.
    • Remove the electrical tape.
  5. Hisense Chromebook C11 Trackpad Replacement: adım 5, 3 resimden 1. Hisense Chromebook C11 Trackpad Replacement: adım 5, 3 resimden 2. Hisense Chromebook C11 Trackpad Replacement: adım 5, 3 resimden 3.
    • Flip up the bracket holding the ribbon in place.
    • Gently but firmly pull the ribbon free.
  6. Hisense Chromebook C11 Trackpad Replacement: adım 6, 1 resimden 1.
    • Using the Phillips Head Screwdriver, remove the screws at the topmost part of the panel holding the trackpad in place.
  7. Hisense Chromebook C11 Trackpad Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, remove the silver electrical tape.
  8. Hisense Chromebook C11 Trackpad Replacement: adım 8, 1 resimden 1.
    • Carefully remove the trackpad from the computer.
Sonuç
Cole Welham
121 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Leahy Fall 2018 USF Tampa, Team S1-G3, Leahy Fall 2018 üyesi
USFT-LEAHY-F18S1G3
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 304
