Ana içeriğe geç
Hisense Sero 7 Pro Rear Camera Replacement
Neye ihtiyacın var
  1. Hisense Sero 7 Pro Rear Camera Replacement, Rear Camera: adım 1, 2 resimden 1. Hisense Sero 7 Pro Rear Camera Replacement, Rear Camera: adım 1, 2 resimden 2.
    • Turn tablet off before dissembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro Rear Camera Replacement: adım 2, 1 resimden 1.
    • Using a metal or nylon spudger, begin to peel the tape from the motherboard that it is attached to the camera.
    • If needed, the same steps can be applied to front camera.
  3. Hisense Sero 7 Pro Rear Camera Replacement: adım 3, 3 resimden 1. Hisense Sero 7 Pro Rear Camera Replacement: adım 3, 3 resimden 2. Hisense Sero 7 Pro Rear Camera Replacement: adım 3, 3 resimden 3.
    • Pull the camera toward you to detach from the tablet.
    • Use caution when detaching camera from port.
Sonuç
Baochau Nguyen
314 İtibar
3 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 38-2, Bennett Fall 2016 Texas Tech, Team 38-2, Bennett Fall 2016 üyesi
TTU-BENNETT-F16S38G2
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 218
