Ana içeriğe geç
Hisense Sero 7 Pro Speakers Replacement
Neye ihtiyacın var
  1. Hisense Sero 7 Pro Speakers Replacement, Battery: adım 1, 2 resimden 1. Hisense Sero 7 Pro Speakers Replacement, Battery: adım 1, 2 resimden 2.
    • Turn tablet off before dissembling it.
    • Use caution when handling device if screen is cracked.
    • Using a plastic opening tool, pry open the back cover from the tablet.
    • An extra set of hands may be required.
  2. Hisense Sero 7 Pro Speakers Replacement: adım 2, 2 resimden 1. Hisense Sero 7 Pro Speakers Replacement: adım 2, 2 resimden 2.
    • Use a spudger to disconnect the battery from the motherboard.
  3. Hisense Sero 7 Pro Speakers Replacement: adım 3, 2 resimden 1. Hisense Sero 7 Pro Speakers Replacement: adım 3, 2 resimden 2.
    • Using a plastic opening tool, carefully place under one corner of the battery.
    • Move around edges of the battery to lift it off of the tablet.
    • Remove battery from tablet.
  4. Hisense Sero 7 Pro Speakers Replacement, Speakers: adım 4, 3 resimden 1. Hisense Sero 7 Pro Speakers Replacement, Speakers: adım 4, 3 resimden 2. Hisense Sero 7 Pro Speakers Replacement, Speakers: adım 4, 3 resimden 3.
    • Peel back the film holding the speaker wire in place
    • Detach both wire connectors
  5. Hisense Sero 7 Pro Speakers Replacement: adım 5, 1 resimden 1.
    • Using a plastic opening tool, carefully place under one corner of each speaker
    • Remove both speakers
Sonuç
Logan Phillips
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S4-G1, Harley Spring 2017 IUPUI, Team S4-G1, Harley Spring 2017 üyesi
IUPUI-HARLEY-S17S4G1
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 146
