Ana içeriğe geç
Hisense Sero 8 Charging Port Replacement
Neye ihtiyacın var
  1. Hisense Sero 8 Charging Port Replacement, Charging Port: adım 1, 3 resimden 1. Hisense Sero 8 Charging Port Replacement, Charging Port: adım 1, 3 resimden 2. Hisense Sero 8 Charging Port Replacement, Charging Port: adım 1, 3 resimden 3.
    • Remove the back cover of the device using a combination of both plastic opening tools.
    • Use your plastic opening tool pry open a corner of the device, then continue down the side of the device with the tool to completely open the device.
  2. Hisense Sero 8 Charging Port Replacement: adım 2, 1 resimden 1.
    • Remove seven of the 4.43mm screws using the Philips #00 screwdriver.
    • It is not necessary to remove the bottom two 4.43mm screws that keep the speakers in place.
  3. Hisense Sero 8 Charging Port Replacement: adım 3, 2 resimden 1. Hisense Sero 8 Charging Port Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Gently lift the motherboard up to extract the charging port out with the tweezers.
    • Be cautious not to disconnect any wires or ribbon cables.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Keanu
367 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Leahy Winter 2015 USF Tampa, Team 1-2, Leahy Winter 2015 üyesi
USFT-LEAHY-W15S1G2
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 3,811
