Ana içeriğe geç
Hitachi CP-X2010N Lens Replacement
Neye ihtiyacın var
    1. Hitachi CP-X2010N Lens Replacement, Top Panel: adım 1, 3 resimden 1. Hitachi CP-X2010N Lens Replacement, Top Panel: adım 1, 3 resimden 2. Hitachi CP-X2010N Lens Replacement, Top Panel: adım 1, 3 resimden 3.
      • Flip the projector upside down to expose the screws on the underside.
      FixBot'a Sor
      Yorum Ekle
    2. Hitachi CP-X2010N Lens Replacement: adım 2, 3 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 2, 3 resimden 2. Hitachi CP-X2010N Lens Replacement: adım 2, 3 resimden 3.
      • Use a Phillips #2 screwdriver to remove eight black 14 mm screws holding the top panel to the main projector body.
      FixBot'a Sor
      Yorum Ekle
    3. Hitachi CP-X2010N Lens Replacement: adım 3, 1 resimden 1.
      • Flip projector right side up and orient it so you are facing the rear panel.
      FixBot'a Sor
      Yorum Ekle
    4. Hitachi CP-X2010N Lens Replacement: adım 4, 3 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 4, 3 resimden 2. Hitachi CP-X2010N Lens Replacement: adım 4, 3 resimden 3.
      • Use a Phillips #2 screwdriver to remove two silver 22 mm long screws.
      • Use a Phillips #2 screwdriver to remove the short silver 10 mm screw.
      FixBot'a Sor
      Yorum Ekle
    5. Hitachi CP-X2010N Lens Replacement: adım 5, 3 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 5, 3 resimden 2. Hitachi CP-X2010N Lens Replacement: adım 5, 3 resimden 3.
      • Carefully lift the top panel from the body of the projector, making sure it doesn't catch on anything.
      • Remove the panel from the body of the projector.
      FixBot'a Sor
      Yorum Ekle
    1. Hitachi CP-X2010N Lens Replacement, Motherboard: adım 6, 3 resimden 1. Hitachi CP-X2010N Lens Replacement, Motherboard: adım 6, 3 resimden 2. Hitachi CP-X2010N Lens Replacement, Motherboard: adım 6, 3 resimden 3.
      • Carefully pinch the edges of the two blue connectors and pull upwards to remove them from the motherboard.
      • Carefully pinch and remove the small gray connector next to the blue wire opposite the speakers.
      FixBot'a Sor
      Yorum Ekle
    2. Hitachi CP-X2010N Lens Replacement: adım 7, 3 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 7, 3 resimden 2. Hitachi CP-X2010N Lens Replacement: adım 7, 3 resimden 3.
      • Use a Phillips #2 screwdriver to remove the two black 14 mm screws securing the button array.
      • Move the wires for better access to the screws if needed.
      FixBot'a Sor
      Yorum Ekle
    3. Hitachi CP-X2010N Lens Replacement: adım 8, 3 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 8, 3 resimden 2. Hitachi CP-X2010N Lens Replacement: adım 8, 3 resimden 3.
      • Remove the bracket that was being held by the screw.
      • Take a picture or memorize its orientation for easier reinstallation.
      FixBot'a Sor
      Yorum Ekle
    4. Hitachi CP-X2010N Lens Replacement: adım 9, 2 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 9, 2 resimden 2.
      • Pull the button array and network adapter out carefully.
      • Make sure all the wires connected to the array are unplugged.
      FixBot'a Sor
      Yorum Ekle
    5. Hitachi CP-X2010N Lens Replacement: adım 10, 2 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 10, 2 resimden 2.
      • Use a Phillips #2 screwdriver to remove the silver 10 mm screw securing the ground wire.
      • Keep the screw and washer in an easily accessible place.
      FixBot'a Sor
      Yorum Ekle
    6. Hitachi CP-X2010N Lens Replacement: adım 11, 1 resimden 1.
      • Use a Phillips #2 screwdriver to remove the black 14 mm screw securing the motherboard to the case.
      FixBot'a Sor
      Yorum Ekle
    7. Hitachi CP-X2010N Lens Replacement: adım 12, 3 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 12, 3 resimden 2. Hitachi CP-X2010N Lens Replacement: adım 12, 3 resimden 3.
      • Delicately pinch and pull off all the wired connections surrounding the outside of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    8. Hitachi CP-X2010N Lens Replacement: adım 13, 3 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 13, 3 resimden 2. Hitachi CP-X2010N Lens Replacement: adım 13, 3 resimden 3.
      • Use the tip of a spudger or your fingernail to flip up the small locking flap on the three orange cable locks. Then, you can safely pull the cables out.
      • Too much force could break the ribbon cable.
      FixBot'a Sor
      Yorum Ekle
    9. Hitachi CP-X2010N Lens Replacement: adım 14, 2 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 14, 2 resimden 2.
      • Lift the motherboard out from the projector carefully so that it doesn't catch on any other components.
      FixBot'a Sor
      Yorum Ekle
    1. Hitachi CP-X2010N Lens Replacement, Lens: adım 15, 3 resimden 1. Hitachi CP-X2010N Lens Replacement, Lens: adım 15, 3 resimden 2. Hitachi CP-X2010N Lens Replacement, Lens: adım 15, 3 resimden 3.
      • Use a Phillips #2 screwdriver to remove the three black 14 mm screws holding down the projector housing.
      FixBot'a Sor
      Yorum Ekle
    2. Hitachi CP-X2010N Lens Replacement: adım 16, 2 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 16, 2 resimden 2.
      • Loosen the three silver Phillips #2 screws that secure the lamp housing.
      • The screws are captive and do not need to be removed from the lamp housing.
      FixBot'a Sor
      Yorum Ekle
    3. Hitachi CP-X2010N Lens Replacement: adım 17, 2 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 17, 2 resimden 2.
      • Work the projector housing loose from the two pins on the lamp housing.
      FixBot'a Sor
      Yorum Ekle
    4. Hitachi CP-X2010N Lens Replacement: adım 18, 3 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 18, 3 resimden 2. Hitachi CP-X2010N Lens Replacement: adım 18, 3 resimden 3.
      • Lift the projector housing up from the left side and remove it from the case.
      FixBot'a Sor
      Yorum Ekle
    5. Hitachi CP-X2010N Lens Replacement: adım 19, 3 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 19, 3 resimden 2. Hitachi CP-X2010N Lens Replacement: adım 19, 3 resimden 3.
      • Turn the front lens element counterclockwise and lift it off the projector housing.
      • The front element will have lubricant on the inside shaft. Take care not to rub any of it off.
      FixBot'a Sor
      Yorum Ekle
    6. Hitachi CP-X2010N Lens Replacement: adım 20, 3 resimden 1. Hitachi CP-X2010N Lens Replacement: adım 20, 3 resimden 2. Hitachi CP-X2010N Lens Replacement: adım 20, 3 resimden 3.
      • Inspect all glass elements for debris or damage.
      • Clean or replace the lens as needed.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Chance Kidd
1.184 İtibar
6 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 413
