Ana içeriğe geç
Hitachi CP-X2010N Top Panel Replacement
Neye ihtiyacın var
    1. Hitachi CP-X2010N Top Panel Replacement, Top Panel: adım 1, 3 resimden 1. Hitachi CP-X2010N Top Panel Replacement, Top Panel: adım 1, 3 resimden 2. Hitachi CP-X2010N Top Panel Replacement, Top Panel: adım 1, 3 resimden 3.
      • Flip the projector upside down to expose the screws on the underside.
      FixBot'a Sor
      Yorum Ekle
    2. Hitachi CP-X2010N Top Panel Replacement: adım 2, 3 resimden 1. Hitachi CP-X2010N Top Panel Replacement: adım 2, 3 resimden 2. Hitachi CP-X2010N Top Panel Replacement: adım 2, 3 resimden 3.
      • Use a Phillips #2 screwdriver to remove eight black 14 mm screws holding the top panel to the main projector body.
      FixBot'a Sor
      Yorum Ekle
    3. Hitachi CP-X2010N Top Panel Replacement: adım 3, 1 resimden 1.
      • Flip projector right side up and orient it so you are facing the rear panel.
      FixBot'a Sor
      Yorum Ekle
    4. Hitachi CP-X2010N Top Panel Replacement: adım 4, 3 resimden 1. Hitachi CP-X2010N Top Panel Replacement: adım 4, 3 resimden 2. Hitachi CP-X2010N Top Panel Replacement: adım 4, 3 resimden 3.
      • Use a Phillips #2 screwdriver to remove two silver 22 mm long screws.
      • Use a Phillips #2 screwdriver to remove the short silver 10 mm screw.
      FixBot'a Sor
      Yorum Ekle
    5. Hitachi CP-X2010N Top Panel Replacement: adım 5, 3 resimden 1. Hitachi CP-X2010N Top Panel Replacement: adım 5, 3 resimden 2. Hitachi CP-X2010N Top Panel Replacement: adım 5, 3 resimden 3.
      • Carefully lift the top panel from the body of the projector, making sure it doesn't catch on anything.
      • Remove the panel from the body of the projector.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Chance Kidd
1.184 İtibar
6 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 290
