Ana içeriğe geç
Hitachi CP-X440 Air Filter Replacement
Neye ihtiyacın var
  1. Hitachi CP-X440 Air Filter Replacement, Air Filter: adım 1, 3 resimden 1. Hitachi CP-X440 Air Filter Replacement, Air Filter: adım 1, 3 resimden 2. Hitachi CP-X440 Air Filter Replacement, Air Filter: adım 1, 3 resimden 3.
    • Begin with turning the projector on its side so the bottom of the device is clearly visible.
    FixBot'a Sor
    Yorum Ekle
  2. Hitachi CP-X440 Air Filter Replacement: adım 2, 3 resimden 1. Hitachi CP-X440 Air Filter Replacement: adım 2, 3 resimden 2. Hitachi CP-X440 Air Filter Replacement: adım 2, 3 resimden 3.
    • In the bottom left hand corner of the device there will be a vent.
    • At the bottom of the vent, there will be two pull tabs. Remove the vent by gently pushing up on the tabs.
    • Once the tabs are pushed, the vent will pop out and will be able to easily be taken off the device.
    FixBot'a Sor
    Yorum Ekle
  3. Hitachi CP-X440 Air Filter Replacement: adım 3, 2 resimden 1. Hitachi CP-X440 Air Filter Replacement: adım 3, 2 resimden 2.
    • Once the vent is removed, you will see the black air filter.
    • To remove the air filter, gently grab the center handle and pull.
    • The air filter can be discarded into a waste basket.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Harper Hollon
238 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 18
Her zaman: 465
