Ana içeriğe geç
Hitachi CP-X440 Lens Replacement
Neye ihtiyacın var
  1. Hitachi CP-X440 Lens Replacement, Motherboard: adım 1, 1 resimden 1.
    • Turn the projector upside down so the bottom is facing up.
    • Using a Phillips #1 screwdriver remove the six black 2 mm screws.
    • The screws are deep in the holes, so be careful when removing them as they can easily fall off the screwdriver tip.
    FixBot'a Sor
    Yorum Ekle
  2. Hitachi CP-X440 Lens Replacement: adım 2, 2 resimden 1. Hitachi CP-X440 Lens Replacement: adım 2, 2 resimden 2.
    • Flip the projector right-side up and navigate to the back panel.
    • Remove the three black 10 mm screws on the back panel with a Phillips #1 screwdriver.
    • Remove the two silver 10 mm screws on the power switch panel with a Phillips #1 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Hitachi CP-X440 Lens Replacement: adım 3, 2 resimden 1. Hitachi CP-X440 Lens Replacement: adım 3, 2 resimden 2.
    • Now turn the projector so the front is facing you.
    • Gently remove the lid from the bottom of the projector so the green circuit board is exposed.
    FixBot'a Sor
    Yorum Ekle
  4. Hitachi CP-X440 Lens Replacement: adım 4, 2 resimden 1. Hitachi CP-X440 Lens Replacement: adım 4, 2 resimden 2.
    • Gently remove the cables from their white connectors on the circuit board.
    FixBot'a Sor
    Yorum Ekle
  5. Hitachi CP-X440 Lens Replacement: adım 5, 1 resimden 1.
    • Gently pull out the three orange ribbons from their white connectors on the circuit board.
    • You can use a spudger tool to pry them out of place.
    FixBot'a Sor
    Yorum Ekle
  6. Hitachi CP-X440 Lens Replacement: adım 6, 1 resimden 1.
    • Remove the five silver 5 mm screws on the circuit board with a Phillips #2 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Hitachi CP-X440 Lens Replacement: adım 7, 1 resimden 1.
    • Remove the motherboard so the projector is exposed.
    FixBot'a Sor
    Yorum Ekle
  8. Hitachi CP-X440 Lens Replacement, Lens: adım 8, 3 resimden 1. Hitachi CP-X440 Lens Replacement, Lens: adım 8, 3 resimden 2. Hitachi CP-X440 Lens Replacement, Lens: adım 8, 3 resimden 3.
    • As you look at the the device overhead, you will see three pieces of orange ribbon.
    • Attached to the orange ribbon will be a stabilizer over the lamp.
    • On each side, unscrew the two 1 cm screws with a Phillips #0 Screwdriver.
    • Then remove the piece holding the orange ribbons, called the stabilizer from this point on.
    FixBot'a Sor
    Yorum Ekle
  9. Hitachi CP-X440 Lens Replacement: adım 9, 3 resimden 1. Hitachi CP-X440 Lens Replacement: adım 9, 3 resimden 2. Hitachi CP-X440 Lens Replacement: adım 9, 3 resimden 3.
    • Once the stabilizer is removed, set it to the side.
    • Use a Phillips #0 screwdriver to remove the two 1 cm screws on both sides of the lens.
    • The lens element should be easily lifted out of the device.
    FixBot'a Sor
    Yorum Ekle
  10. Hitachi CP-X440 Lens Replacement: adım 10, 2 resimden 1. Hitachi CP-X440 Lens Replacement: adım 10, 2 resimden 2.
    • Once the lens element is safely removed, you will see 4 tiny 1/2 centimeter screws surrounding the lens.
    • Use a Phillips #000 screwdriver to unscrew each screw. This will allow you to easily remove the lens.
    FixBot'a Sor
    Yorum Ekle
  11. Hitachi CP-X440 Lens Replacement: adım 11, 3 resimden 1. Hitachi CP-X440 Lens Replacement: adım 11, 3 resimden 2. Hitachi CP-X440 Lens Replacement: adım 11, 3 resimden 3.
    • Once the lens is safely removed, turn it face up.
    FixBot'a Sor
    Yorum Ekle
  12. Hitachi CP-X440 Lens Replacement: adım 12, 2 resimden 1. Hitachi CP-X440 Lens Replacement: adım 12, 2 resimden 2.
    • Begin to gently unscrew the lens by hand, being mindful of light pressure.
    • After a few turns, the lens should be easily removed.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Harper Hollon
238 İtibar
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 404
