Ana içeriğe geç
Hitachi CP-X440 Sensor Replacement
Neye ihtiyacın var
  1. Hitachi CP-X440 Sensor Replacement, Sensor: adım 1, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the six 2 cm screws from the bottom of the case.
    FixBot'a Sor
    Yorum Ekle
  2. Hitachi CP-X440 Sensor Replacement: adım 2, 2 resimden 1. Hitachi CP-X440 Sensor Replacement: adım 2, 2 resimden 2.
    • Flip the projector back upright and place the back of projector towards you. Unscrew the 3 screws circled in the back with your Phillips #1 Screwdriver. Each screw is 1 cm in length.
    • Then unscrew the two silver, 1 cm screws on the light switch panel with a Phillips #1 Screwdriver
    FixBot'a Sor
    Yorum Ekle
  3. Hitachi CP-X440 Sensor Replacement: adım 3, 3 resimden 1. Hitachi CP-X440 Sensor Replacement: adım 3, 3 resimden 2. Hitachi CP-X440 Sensor Replacement: adım 3, 3 resimden 3.
    • You will now be able to pop the top of the projector off.
    • To uncollapse the projector top fully from the projector, you can pull the black cord from the white holder near the lens, circled in red and orange.
    • With front of projector now facing you, the sensor can be found on the left of the lens.
    FixBot'a Sor
    Yorum Ekle
  4. Hitachi CP-X440 Sensor Replacement: adım 4, 2 resimden 1. Hitachi CP-X440 Sensor Replacement: adım 4, 2 resimden 2.
    • The sensor will be held into the projector by a silver screw on the lower left side of lens. This single 2 mm screw will need to be unscrewed and removed. This will allow you to remove the sensor piece completely out of the projector.
    • You now will remove the sensor piece completely.
    FixBot'a Sor
    Yorum Ekle
  5. Hitachi CP-X440 Sensor Replacement: adım 5, 3 resimden 1. Hitachi CP-X440 Sensor Replacement: adım 5, 3 resimden 2. Hitachi CP-X440 Sensor Replacement: adım 5, 3 resimden 3.
    • To get the sensor piece alone, you will unscrew the single 3 mm silver screw.
    • Once this screw in the sensor piece is removed, the sensor piece will be alone and can be replaced with your new one.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 25
Her zaman: 369
