Ana içeriğe geç
Hitachi HB-B102 Automatic Home Bakery II Control Panel Replacement
Neye ihtiyacın var
  1. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement, Control Panel: adım 1, 1 resimden 1.
    • Begin by using a # 2 Phillips head screwdriver to remove the two 1.3 cm screws that secure the control panel onto the main body.
  2. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: adım 2, 1 resimden 1.
    • Now gently pry on the top of the control panel with a metal spudger, it should then pop up.
    • Be careful when it is being removed that you do not damage the tabs that hold the bottom of the panel in place.
  3. Hitachi HB-B102 Automatic Home Bakery  II Control Panel Replacement: adım 3, 1 resimden 1.
    • Now flip the control panel over so that the wire connections are visible.
    • All of the wires are easily removed by grabbing the metal connector and pulling straight out from the panel.
Sonuç
Mike
397 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-2, Banghart Winter 2017 Cal Poly, Team 9-2, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S9G2
3 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Where can i buy the power board for hitachi home
bakery HD II -B102 and how much is the price?
janettecrown_66 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 404
