Ana içeriğe geç
Hockey Glove Palm Repair
Neye ihtiyacın var
  1. Hockey Glove Palm Repair, Hockey Glove Palm Repair: adım 1, 1 resimden 1.
    • Using measuring tape, measure the dimensions of the hole to approximate how much material is needed.
  2. Hockey Glove Palm Repair: adım 2, 2 resimden 1. Hockey Glove Palm Repair: adım 2, 2 resimden 2.
    • Using the dimensions gathered from the previous step, cut the fabric to size leaving some excess material.
    • You can use fabric from other gloves that are still intact to repair the glove in need.
  3. Hockey Glove Palm Repair: adım 3, 1 resimden 1.
    • Draw an approximate shape of the hole on the fabric as a guide for stitching using a marking tool that will show up on fabric.
  4. Hockey Glove Palm Repair: adım 4, 2 resimden 1. Hockey Glove Palm Repair: adım 4, 2 resimden 2.
    • Thread a needle with enough thread for the size of the hole you are repairing.
    • A sewing machine can be used instead of hand sewing if you would prefer.
  5. Hockey Glove Palm Repair: adım 5, 2 resimden 1. Hockey Glove Palm Repair: adım 5, 2 resimden 2.
    • Apply the adhesive to the perimeter of the hole.
  6. Hockey Glove Palm Repair: adım 6, 1 resimden 1.
    • Position the material on the glove to completely cover the hole leaving a bit of overlap.
    • Allow the adhesive time to dry so that the material is firmly stuck to the glove.
  7. Hockey Glove Palm Repair: adım 7, 2 resimden 1. Hockey Glove Palm Repair: adım 7, 2 resimden 2.
    • Reinforce replacement material to the palm through hand stitching.
    • To hand stitch, push the needle through the front of the fabric and pull the thread through. Do the same from the inside of the glove. Continue to weave in and out creating stitches that are as close together as possible.
  8. Hockey Glove Palm Repair: adım 8, 1 resimden 1.
    • Trim excess the material from around the area of replacement
Sonuç
Dora D'Accardo
157 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-6, Morris Spring 2023 UC Davis, Team 1-6, Morris Spring 2023 üyesi
UCD-MORRIS-S23S1G6
3 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 20
Son 30 gün: 69
Her zaman: 3,020
