Ana içeriğe geç
Hockey Helmet Cage Replacement
Neye ihtiyacın var
  1. Hockey Helmet Cage Replacement, Cage: adım 1, 3 resimden 1. Hockey Helmet Cage Replacement, Cage: adım 1, 3 resimden 2. Hockey Helmet Cage Replacement, Cage: adım 1, 3 resimden 3.
    • Unscrew the hinge clips from the front of the helmet.
    • This separates the old cage from the helmet.
  2. Hockey Helmet Cage Replacement: adım 2, 3 resimden 1. Hockey Helmet Cage Replacement: adım 2, 3 resimden 2. Hockey Helmet Cage Replacement: adım 2, 3 resimden 3.
    • Replace the screw clips on the sides of the helmet with the ones from the new cage.
    • Different companies have different sized clip screws so it is important to install the new ones that come with your cage.
  3. Hockey Helmet Cage Replacement: adım 3, 3 resimden 1. Hockey Helmet Cage Replacement: adım 3, 3 resimden 2. Hockey Helmet Cage Replacement: adım 3, 3 resimden 3.
    • Clip the new hinge clips onto the top center of the new cage.
    • Make sure the flat side of the hinge is facing towards the inside of the cage, and that it is pointed upward.
  4. Hockey Helmet Cage Replacement: adım 4, 3 resimden 1. Hockey Helmet Cage Replacement: adım 4, 3 resimden 2. Hockey Helmet Cage Replacement: adım 4, 3 resimden 3.
    • Align the hinge holes with the screw holes in the center of the helmet.
    • Once everything is lined up, screw the hinges into the holes in the helmet to attach the cage to the helmet.
  5. Hockey Helmet Cage Replacement: adım 5, 3 resimden 1. Hockey Helmet Cage Replacement: adım 5, 3 resimden 2. Hockey Helmet Cage Replacement: adım 5, 3 resimden 3.
    • Make sure now that the cage is on that it has full range of motion.
    • It should fit under the J clips on the sides of the helmet when pushed up.
    • It should be able to extend 90 degrees outward.
  6. Hockey Helmet Cage Replacement: adım 6, 3 resimden 1. Hockey Helmet Cage Replacement: adım 6, 3 resimden 2. Hockey Helmet Cage Replacement: adım 6, 3 resimden 3.
    • Now tighten the straps on either side of the cage.
    • Clip the straps into the screws on either side of the helmet to check how tight it is.
    • The straps should be tight to the screw clip, and the cage should be touching the j-clip.
    • Once you do this and you put the helmet on, if your chin is sitting perfectly in the chin guard, the helmet and cage will not move from their position if you shake or nod your head.
Sonuç
Make sure all of the screws are tight, and you have just completed the replacement of the hockey helmet cage!
Bir başkası bu kılavuzu tamamladı.
Blake Donovan
195 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 37
Son 30 gün: 119
Her zaman: 7,386
