Ana içeriğe geç
Holmes HEH8031 Control Buttons Replacement
Neye ihtiyacın var
  1. Holmes HEH8031 Control Buttons Replacement, Housing: adım 1, 1 resimden 1.
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Control Buttons Replacement: adım 2, 1 resimden 1.
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Control Buttons Replacement: adım 3, 2 resimden 1. Holmes HEH8031 Control Buttons Replacement: adım 3, 2 resimden 2.
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Control Buttons Replacement, Circuit Board Removal: adım 4, 1 resimden 1.
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Control Buttons Replacement, Control Buttons: adım 5, 3 resimden 1. Holmes HEH8031 Control Buttons Replacement, Control Buttons: adım 5, 3 resimden 2. Holmes HEH8031 Control Buttons Replacement, Control Buttons: adım 5, 3 resimden 3.
    • Remove the two Phillips #2 12mm screws from the button retainer.
    • Lift the button retainer off.
    • Remove the interconnected buttons.
    • If the buttons are broken, replace them.
    • If the buttons are sticking, clean them in warm soapy water and allow to dry.
  6. Holmes HEH8031 Control Buttons Replacement: adım 6, 3 resimden 1. Holmes HEH8031 Control Buttons Replacement: adım 6, 3 resimden 2. Holmes HEH8031 Control Buttons Replacement: adım 6, 3 resimden 3.
    • Using light finger pressure, carefully push the black plastic tabs off the white plastic hooks.
    • Remove the black plastic bracket out through the front of the heater housing.
    • Remove the two Phillips #2 12mm screws and remove the clear window from the black plastic bracket.
    • If the buttons were sticking, clean the black plastic bracket in warm soapy water and allow to dry.
    • If the clear window was dirty, clean it in warm soapy water and allow to dry.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris Shaffer
255 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S2G1
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 516
