Ana içeriğe geç
Holmes HEH8031 Power Cord Replacement
Neye ihtiyacın var
  1. Holmes HEH8031 Power Cord Replacement, Housing: adım 1, 1 resimden 1.
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Power Cord Replacement: adım 2, 1 resimden 1.
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Power Cord Replacement: adım 3, 2 resimden 1. Holmes HEH8031 Power Cord Replacement: adım 3, 2 resimden 2.
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Power Cord Replacement, Power Cord: adım 4, 3 resimden 1. Holmes HEH8031 Power Cord Replacement, Power Cord: adım 4, 3 resimden 2. Holmes HEH8031 Power Cord Replacement, Power Cord: adım 4, 3 resimden 3.
    • Decrimp the wire nuts from both wire connections.
    • Remove wire nuts to expose wire strands.
    • Separate all connected wires.
  5. Holmes HEH8031 Power Cord Replacement: adım 5, 3 resimden 1. Holmes HEH8031 Power Cord Replacement: adım 5, 3 resimden 2. Holmes HEH8031 Power Cord Replacement: adım 5, 3 resimden 3.
    • Pull on the cord from the outside of the heater with great finesse. At the same time, push the cord clamp out of the housing from the inside.
    • Separate the two halves of the cord clamp and remove from cord.
  6. Holmes HEH8031 Power Cord Replacement: adım 6, 2 resimden 1. Holmes HEH8031 Power Cord Replacement: adım 6, 2 resimden 2.
    • Prepare the replacement cord by cutting the negative branch (black) at least 8 inches shorter than the positive branch (white).
    • Strip at least 3/4 inch of insulation from the cord to expose bare wire.
    • Twist wire ends to form a tight braid.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Deanna Jack
333 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S2G1
4 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
Are there substitute power cord for Holmes HEH8031 power cord replacement?
Terri Allen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 1,922
