Ana içeriğe geç
Holmes HEH8031 Safety Weight Replacement
Neye ihtiyacın var
  1. Holmes HEH8031 Safety Weight Replacement, Housing: adım 1, 1 resimden 1.
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Safety Weight Replacement: adım 2, 1 resimden 1.
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Safety Weight Replacement: adım 3, 2 resimden 1. Holmes HEH8031 Safety Weight Replacement: adım 3, 2 resimden 2.
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Safety Weight Replacement, Circuit Board Removal: adım 4, 1 resimden 1.
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Safety Weight Replacement, Safety Weight: adım 5, 2 resimden 1. Holmes HEH8031 Safety Weight Replacement, Safety Weight: adım 5, 2 resimden 2.
    • Remove wires from safety weight, as shown.
    • Pull upward on the blue connectors.
    • If connectors are tough to remove, try wiggling while pulling upward.
  6. Holmes HEH8031 Safety Weight Replacement: adım 6, 1 resimden 1.
    • Unscrew the Phillips #2 10 mm screw from the safety weight on the rear housing panel.
Sonuç
Deanna Jack
333 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S2G1
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 543
