Ana içeriğe geç
Holmes HEH8031 Thermostat Replacement
Neye ihtiyacın var
  1. Holmes HEH8031 Thermostat Replacement, Housing: adım 1, 1 resimden 1.
    • Ensure the device is unplugged from the wall outlet.
  2. Holmes HEH8031 Thermostat Replacement: adım 2, 1 resimden 1.
    • Remove eight 12-mm Phillips #2 screws from the back cover.
  3. Holmes HEH8031 Thermostat Replacement: adım 3, 2 resimden 1. Holmes HEH8031 Thermostat Replacement: adım 3, 2 resimden 2.
    • Turn heater over so the controls are facing up.
    • Lift the front housing away from the back of the fan and slowly fold the front housing back down to the floor.
    • Internal wires are connected to both halves of the housing. Be careful when separating the housing.
  4. Holmes HEH8031 Thermostat Replacement, Circuit Board Removal: adım 4, 1 resimden 1.
    • Remove four 12mm Phillips #2 screws from the circuit board.
  5. Holmes HEH8031 Thermostat Replacement, Fan: adım 5, 1 resimden 1.
    • Remove two Phillips #2 12mm screws from housing
  6. Holmes HEH8031 Thermostat Replacement: adım 6, 1 resimden 1.
    • Remove zip tie from wire with pliers
  7. Holmes HEH8031 Thermostat Replacement: adım 7, 1 resimden 1.
    • Separate fan assembly from heating coil
  8. Holmes HEH8031 Thermostat Replacement, Thermostat: adım 8, 1 resimden 1.
    • Remove 1 Phillips #2 screw
  9. Holmes HEH8031 Thermostat Replacement: adım 9, 1 resimden 1.
    • Remove thermostat from rear housing
  10. Holmes HEH8031 Thermostat Replacement: adım 10, 1 resimden 1.
    • remove solder from thermostat wire on circuit board
    • Soldering iron will be hot
Sonuç
Bir başkası bu kılavuzu tamamladı.
Richard S Woodruff
142 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 2-1, Baechle Fall 2016 IUPUI, Team 2-1, Baechle Fall 2016 üyesi
IUPUI-BAECHLE-F16S2G1
4 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 1,381
