Ana içeriğe geç
Holmes box fan motor replacement
Neye ihtiyacın var
  1. Holmes box fan motor replacement, Motor: adım 1, 3 resimden 1. Holmes box fan motor replacement, Motor: adım 1, 3 resimden 2. Holmes box fan motor replacement, Motor: adım 1, 3 resimden 3.
    • The first step is to make sure you unplug your fan from the outlet.
    • Make sure you also unplug the power cord from the back of the fan.
  2. Holmes box fan motor replacement: adım 2, 2 resimden 1. Holmes box fan motor replacement: adım 2, 2 resimden 2.
    • Now that your fan is unplugged, lay it flat with the brand label facing upward.
    • Next is to remove the front cover.
    • Remove the six screws from the perimeter of the cover in order to remove the front cover.
  3. Holmes box fan motor replacement: adım 3, 2 resimden 1. Holmes box fan motor replacement: adım 3, 2 resimden 2.
    • Next is the back cover.
    • Flip over the fan so you have access to these six screws.
    • Remove the six screws from the perimeter of the cover in order to remove the back cover.
  4. Holmes box fan motor replacement: adım 4, 1 resimden 1.
    • Remove these four screws in order to remove the motor and fan blades from the housing.
  5. Holmes box fan motor replacement: adım 5, 1 resimden 1.
    • The housing should now be able to lift away from the motor and fan blade.
  6. Holmes box fan motor replacement: adım 6, 3 resimden 1. Holmes box fan motor replacement: adım 6, 3 resimden 2. Holmes box fan motor replacement: adım 6, 3 resimden 3.
    • The next step is to remove the mounts that held the motor to the housing.
    • Remove these four screws to remove the mounts.
  7. Holmes box fan motor replacement: adım 7, 2 resimden 1. Holmes box fan motor replacement: adım 7, 2 resimden 2.
    • Now you are able to remove the motor from the fan blades.
    • Be careful, if you used your fan recently the motor may be quite hot.
  8. Holmes box fan motor replacement: adım 8, 1 resimden 1.
    • Now you can insert your new motor and you are done!
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Max Cossalter
311 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 15-4, Green Fall 2015 Cal Poly, Team 15-4, Green Fall 2015 üyesi
CPSU-GREEN-F15S15G4
4 Üyeler
4 adet Kılavuz yazıldı
4 Yorum
Where might one find a replacement motor for a older box fan
Chris Cook - Yanıt
Also, I would like to know where to get a replacement motor, as shown in step 4.
Vince Doriean - Yanıt
Great guide! Upon reassembling, I noticed that the center of the propeller touches the front grill where it says Holmes. Anyone know if they rub on each other by design?
Zeev - Yanıt
My version of the fan came with a similar cord, however the female end had a bump in the center on the end that latches into the fan. Without shaving that piece off, the plug doesn’t detach without taking it apart and prying it out.
applejack_ - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 52
Her zaman: 12,482
