Giriş
If you believe the battery in your device may be faulty, follow this guide to access the battery compartment. For this guide, you will need a thin Phillip's head screwdriver, tweezers, and a soldering iron once you get to the battery itself.
Neye ihtiyacın var
Make sure your device is turned off by pressing the power button and ensuring the LED lights are off.
Unscrew top from the container by twisting the top of the container counter clockwise and pulling up.
