Ana içeriğe geç
Homedics UHE-CMP15 Charging Cable Cleaning
Neye ihtiyacın var
  1. Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: adım 1, 2 resimden 1. Homedics UHE-CMP15 Charging Cable Cleaning, Homedics UHE-CMP15 Charging Cable Cleaning: adım 1, 2 resimden 2.
    • Check the USB port/both ends of the charging cable for dust or grime buildup.
  2. Homedics UHE-CMP15 Charging Cable Cleaning: adım 2, 2 resimden 1. Homedics UHE-CMP15 Charging Cable Cleaning: adım 2, 2 resimden 2.
    • Clear out any buildup carefully with a plastic tool, never metal.
    • Gently rub the plastic tool of choice along the charging port and remove and dust that may have built up over time.
    • Try the charger again, you should see a red LED indicator if the device is charging.
  3. Homedics UHE-CMP15 Charging Cable Cleaning: adım 3, 1 resimden 1.
    • A red light should appear above the charging port when plugged in, if it does not then the charging cable should be replaced.
    • Purchase a replacement type-c charger or use another charger you already own to test again.
    • If this does not resolve the issue then the battery may be dead, or there is some other issue.
Sonuç
If this guide does not solve your charging problem, check out the battery replacement guide instead.
Kade Betterton
267 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-6, Konn Fall 2023 UMass Dartmouth, Team 3-6, Konn Fall 2023 üyesi
UMASSD-KONN-F23S3G6
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 72
