Ana içeriğe geç
Homelite UT44172 Blades Replacement
Neye ihtiyacın var
    1. Homelite UT44172 Blades Replacement, Removing Screws: adım 1, 1 resimden 1.
      • Remove the six 15.0 mm screws from the body of the device with a Phillips #2 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Homelite UT44172 Blades Replacement, Removing Faceplate: adım 2, 1 resimden 1.
      • Remove the face plate by lifting it away from the other half of the device. This will expose the interior.
      FixBot'a Sor
      Yorum Ekle
    3. Homelite UT44172 Blades Replacement, Exposing Blade Components: adım 3, 2 resimden 1. Homelite UT44172 Blades Replacement, Exposing Blade Components: adım 3, 2 resimden 2.
      • Use the Phillips #2 screwdriver to remove the four 10.0 mm screws on the bottom of the blades.
      FixBot'a Sor
      Yorum Ekle
    4. Homelite UT44172 Blades Replacement, Replacing Blades: adım 4, 3 resimden 1. Homelite UT44172 Blades Replacement, Replacing Blades: adım 4, 3 resimden 2. Homelite UT44172 Blades Replacement, Replacing Blades: adım 4, 3 resimden 3.
      • Remove the old blades by pulling them away from the gears and motor.
      • Be careful handling the blades. They are sharp.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Adam soto
301 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-5, Watkins Winter 2015 USF Tampa, Team 17-5, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G5
3 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 24
Her zaman: 1,172
