Ana içeriğe geç
Homelite UT44172 Blades Replacement
Neye ihtiyacın var
  1. Homelite UT44172 Blades Replacement, Removing Screws: adım 1, 1 resimden 1.
    • Remove the six 15.0 mm screws from the body of the device with a Phillips #2 screwdriver.
  2. Homelite UT44172 Blades Replacement, Removing Faceplate: adım 2, 1 resimden 1.
    • Remove the face plate by lifting it away from the other half of the device. This will expose the interior.
  3. Homelite UT44172 Blades Replacement, Exposing Blade Components: adım 3, 2 resimden 1. Homelite UT44172 Blades Replacement, Exposing Blade Components: adım 3, 2 resimden 2.
    • Use the Phillips #2 screwdriver to remove the four 10.0 mm screws on the bottom of the blades.
  4. Homelite UT44172 Blades Replacement, Replacing Blades: adım 4, 3 resimden 1. Homelite UT44172 Blades Replacement, Replacing Blades: adım 4, 3 resimden 2. Homelite UT44172 Blades Replacement, Replacing Blades: adım 4, 3 resimden 3.
    • Remove the old blades by pulling them away from the gears and motor.
    • Be careful handling the blades. They are sharp.
Sonuç
Adam soto
301 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-5, Watkins Winter 2015 USF Tampa, Team 17-5, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 727
