Ana içeriğe geç
Homelite UT44172 Plastic Casing Replacement
Neye ihtiyacın var
  1. Homelite UT44172 Plastic Casing Replacement, Opening Device: adım 1, 1 resimden 1.
    • Remove the six 15 mm screws from the shear using a Phillips #2 screwdriver.
  2. Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: adım 2, 2 resimden 1. Homelite UT44172 Plastic Casing Replacement, Remove Faceplate: adım 2, 2 resimden 2.
    • Pull the faceplate away from the body of the device and replace it with the new faceplate.
    • Potential for device damage: Be sure to take caution of loose wires during the replacement process.
    • If the plate with the screw sockets was replaced, the wires will need to be put back into the the depressions on the new plate for the device to be closed up properly. See photo with the blades on the right for proper wire placement.
Sonuç
Adam soto
301 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-5, Watkins Winter 2015 USF Tampa, Team 17-5, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G5
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 253
