Ana içeriğe geç
Homelite UT44172 Safety Switch Replacement
Neye ihtiyacın var
    1. Homelite UT44172 Safety Switch Replacement, Opening the device: adım 1, 1 resimden 1.
      • Remove the six 1.5 cm screws marked on the picture from the plastic casing with a Phillips #2 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Homelite UT44172 Safety Switch Replacement, Remove Faceplate: adım 2, 1 resimden 1.
      • Remove the faceplate to expose the inner mechanisms.
      FixBot'a Sor
      Yorum Ekle
    3. Homelite UT44172 Safety Switch Replacement, Switch Removal: adım 3, 3 resimden 1. Homelite UT44172 Safety Switch Replacement, Switch Removal: adım 3, 3 resimden 2. Homelite UT44172 Safety Switch Replacement, Switch Removal: adım 3, 3 resimden 3.
      • Remove the safety switch by pulling it away from the body of device.
      • Be careful not to lose the spring, which is under pressure and may fly out during removal.
      FixBot'a Sor
      Yorum Ekle
    4. Homelite UT44172 Safety Switch Replacement, Spring Replacement: adım 4, 1 resimden 1.
      • Inspect both the spring and the switch to see if either is deformed or damaged. If so, replace the damaged part with a new part.
      • During reassembly, gently move the inner wires out of the way so they do not get caught in the spring.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Daniel Endericavillacis
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 17-5, Watkins Winter 2015 USF Tampa, Team 17-5, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G5
3 Üyeler
20 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 34
Her zaman: 657
