Ana içeriğe geç
Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement
Neye ihtiyacın var
  1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement, Remove the front cover: adım 1, 3 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement, Remove the front cover: adım 1, 3 resimden 2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement, Remove the front cover: adım 1, 3 resimden 3.
    • Use a 10 mm socket to remove the four capped nuts securing the front cover.
    • Remove the front cover.
  2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement, Remove the battery: adım 2, 1 resimden 1.
    • Use an 8 mm socket to disconnect the battery wires from the battery terminals.
    • Disconnect the black negative cable first to prevent the risk of shorting the battery.
    • During reassembly, connect the black negative cable first. Make sure you reconnect the wires in the correct polarity.
  3. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement: adım 3, 2 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement: adım 3, 2 resimden 2.
    • Unclip the battery strap from the lower plate.
  4. Honda 3000 Watt Inverter Generator EU3000IS1AWK Battery Replacement: adım 4, 1 resimden 1.
    • Remove the battery.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
283.365 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.635 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 30
Son 30 gün: 116
Her zaman: 8,442
