Ana içeriğe geç
Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the recoil starter: adım 1, 1 resimden 1.
    • Use a 10 mm socket to remove the three bolts securing the recoil starter.
  2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 2, 3 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 2, 3 resimden 2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 2, 3 resimden 3.
    • Remove the recoil starter and move it out of the way.
    • Be careful not to lose the metal collar in each of the recoil starter's bolt holes.
  3. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the starter pulley: adım 3, 2 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the starter pulley: adım 3, 2 resimden 2.
    • Use a 10 mm socket to remove the two bolts securing the starter pulley.
    • Remove the starter pulley.
  4. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the air cleaner housing bracket: adım 4, 2 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the air cleaner housing bracket: adım 4, 2 resimden 2.
    • Use a 10 mm socket to remove the bolt securing the air cleaner housing bracket.
    • Remove the air cleaner housing bracket.
  5. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the petcock assembly: adım 5, 2 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the petcock assembly: adım 5, 2 resimden 2.
    • Fuel may leak out when you disconnect this hose. Be ready to catch any spillage.
    • Use pliers to squeeze and loosen the hose clamp securing the carburetor fuel line.
    • Pull and disconnect the carburetor fuel line from the petcock assembly.
  6. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 6, 2 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 6, 2 resimden 2.
    • Be sure to drain the fuel tank before you perform this step.
    • Use a large crescent wrench to loosen the petcock assembly from the fuel tank.
    • Residual fuel will leak out as you remove the petcock assembly. Be ready to catch any spillage.
    • Remove the petcock assembly.
  7. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Drain the carburetor bowl: adım 7, 3 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Drain the carburetor bowl: adım 7, 3 resimden 2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Drain the carburetor bowl: adım 7, 3 resimden 3.
    • Place a container below the carburetor drain tube to catch the excess fuel.
    • The carburetor drain screw is located at the bottom of the carburetor.
    • Use a flathead screwdriver to loosen the brass fuel drain screw until fuel begins to drain out of the carburetor.
    • Once you drain the fuel bowl, re-tighten the fuel drain screw.
  8. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the carburetor: adım 8, 1 resimden 1.
  9. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 9, 1 resimden 1.
    • Remove the choke stay.
  10. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 10, 1 resimden 1.
  11. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 11, 3 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 11, 3 resimden 2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 11, 3 resimden 3.
    • Slide the carburetor off the mounting bolts.
    • During reassembly, use the third photo as a reference for how to route the carburetor tubes.
  12. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 12, 1 resimden 1.
    • Disconnect the throttle control connector from the top of the carburetor.
    • Unwrap the throttle control wires from the carburetor.
  13. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 13, 1 resimden 1.
    • Remove the carburetor.
  14. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 14, 1 resimden 1.
  15. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 15, 1 resimden 1.
    • Remove the carburetor insulator.
  16. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 16, 1 resimden 1.
  17. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the fan cover: adım 17, 3 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the fan cover: adım 17, 3 resimden 2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement, Remove the fan cover: adım 17, 3 resimden 3.
    • Use a 10 mm socket to remove the seven bolts securing the fan cover:
    • Four bolts on top
    • One recessed bolt in the bottom left corner
    • Two bolts in the bottom right corner
    • During reassembly, be sure to reattach the ground wire.
  18. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 18, 1 resimden 1.
    • Use a 12 mm socket to remove the mounting nuts securing the front bushings.
  19. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 19, 2 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 19, 2 resimden 2.
    • Insert a pry bar underneath the fan cover.
    • Pry upwards to lift the generator assembly slightly.
  20. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 20, 3 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 20, 3 resimden 2. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 20, 3 resimden 3.
    • As you lift the generator assembly with the pry bar, maneuver and remove the two generator mounts from their recess.
  21. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 21, 1 resimden 1.
    • Use a 10 mm socket to remove the long bolt from the fan cover.
  22. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 22, 2 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 22, 2 resimden 2.
    • Carefully pull the fan cover away from the generator assembly.
    • During reassembly, make sure that the cord grommet is properly slotted into the fan cover.
  23. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 23, 2 resimden 1. Honda 3000 Watt Inverter Generator EU3000IS1AWK Fan Cover Replacement: adım 23, 2 resimden 2.
    • The fan cover is a tight fit. You may need to push the gas tank upwards as you maneuver the fan cover out.
    • Remove the fan cover.
Sonuç
Arthur Shi
283.341 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.633 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 40
