Ana içeriğe geç
Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement
Neye ihtiyacın var
  1. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Honda 6500 Watt Generator EG6500CL AT Safety Precautions: adım 1, 2 resimden 1. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Honda 6500 Watt Generator EG6500CL AT Safety Precautions: adım 1, 2 resimden 2.
    • Before you work on the device, make sure to switch the engine off.
    • Switch the circuit breaker off.
  2. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Disconnect the spark plug: adım 2, 2 resimden 1. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Disconnect the spark plug: adım 2, 2 resimden 2.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: adım 3, 2 resimden 1. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: adım 3, 2 resimden 2.
    • Twist the fuel valve clockwise into the cutoff position.
  4. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Remove the generator cover: adım 4, 1 resimden 1.
    • Use a Phillips screwdriver to remove the two screws securing the generator cover.
  5. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: adım 5, 2 resimden 1. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: adım 5, 2 resimden 2.
    • Remove the generator cover.
  6. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Remove the brush assembly: adım 6, 2 resimden 1. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement, Remove the brush assembly: adım 6, 2 resimden 2.
    • Squeeze and disconnect the stator connector from the wiring harness.
  7. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: adım 7, 2 resimden 1. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: adım 7, 2 resimden 2.
    • Use a 10 mm socket to remove the bolt securing the brush assembly.
    • Pull the brush assembly out slightly from its recess.
  8. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: adım 8, 2 resimden 1. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: adım 8, 2 resimden 2.
    • Disconnect the two spade connectors from the brush assembly.
  9. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: adım 9, 2 resimden 1. Honda 6500 Watt Generator EG6500CL AT Brush Assembly Replacement: adım 9, 2 resimden 2.
    • Remove the brush assembly.
    • During reassembly, use the second photo as reference for how to wire the brush assembly.
Sonuç
Arthur Shi
283.144 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.548 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 840
