Ana içeriğe geç
Honda Accord Car Key Remote
Neye ihtiyacın var
  1. Honda Accord Car Key Remote, Replacing the battery: adım 1, 2 resimden 1. Honda Accord Car Key Remote, Replacing the battery: adım 1, 2 resimden 2.
    • Locate the screw in the middle of your car key.
    • Make sure you have the following tools - Tri-point Screwdriver - CR2032 Battery
  2. Honda Accord Car Key Remote: adım 2, 1 resimden 1.
    • With your screwdriver, begin to screw in a counter-clockwise motion.
  3. Honda Accord Car Key Remote: adım 3, 1 resimden 1.
    • Each key should have a small gap. Locate this gap on the side of your key.
    • After you have taken off the screw, place the small screw somewhere safe. Then with the same screwdriver or a flathead screwdriver, you want to apply pressure to the small gap to pop it open.
  4. Honda Accord Car Key Remote: adım 4, 3 resimden 1. Honda Accord Car Key Remote: adım 4, 3 resimden 2. Honda Accord Car Key Remote: adım 4, 3 resimden 3.
    • This is an example of how the key should look after you pop it open.
  5. Honda Accord Car Key Remote: adım 5, 1 resimden 1.
    • Do not touch the other half of the key
    • After popping open the key, the battery should be located on the left half of the key.
  6. Honda Accord Car Key Remote: adım 6, 1 resimden 1.
    • Apply pressure with the flathead screwdriver, and the battery should pop out once again.
  7. Honda Accord Car Key Remote: adım 7, 2 resimden 1. Honda Accord Car Key Remote: adım 7, 2 resimden 2.
    • swap the old battery with the new battery
    • Make sure the smooth part of the battery is facing inside and not facing outwards as shown on the picture
  8. Honda Accord Car Key Remote: adım 8, 1 resimden 1.
    • Lastly, place the key back together and screw the middle part back with the tri-point screwdriver.
Sonuç
Emerson Corado
157 İtibar
1 Kılavuz yazıldı
Bir Yorum
You listed the wrong battery. It uses a CR1620 not a CR2032. Your picture even shows the correct battery. Also I believe it is a P000 screwdriver, that is what fit my 2013 Accord key.
Mark Fox - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 256
