Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Follow this guide to replace a broken throttle lever on the Honda FC600 tiller.
  1. Before you begin, it's important that you completely cut power to the tiller by disconnecting the spark plug. This will prevent the engine from accidentally starting up while you're working on the tiller. Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine. Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine.
    • Before you begin, it's important that you completely cut power to the tiller by disconnecting the spark plug. This will prevent the engine from accidentally starting up while you're working on the tiller.
    • Grab the spark plug cap and pull it straight out to disconnect the spark plug from the engine.
  2. Push the throttle lever all the way down. Push the throttle lever all the way down.
    • Push the throttle lever all the way down.
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. Remove the 23 mm-long Phillips #2 screw securing the throttle lever to the handlebar.
    • Remove the 23 mm-long Phillips #2 screw securing the throttle lever to the handlebar.
    • This screw is accompanied by a square nut. Make sure to retain it for re-assembly.
  5. Use a pair of needle-nose pliers to remove the small clip attached to the throttle cable. Use a pair of needle-nose pliers to remove the small clip attached to the throttle cable.
    • Use a pair of needle-nose pliers to remove the small clip attached to the throttle cable.
  6. Grab the open end of the throttle cable and pull it out of the throttle lever to free it from its recess. Grab the open end of the throttle cable and pull it out of the throttle lever to free it from its recess.
    • Grab the open end of the throttle cable and pull it out of the throttle lever to free it from its recess.
  7. Continue to lift the throttle cable out of the throttle lever, making sure it clears the openings in the recess. Continue to lift the throttle cable out of the throttle lever, making sure it clears the openings in the recess. Continue to lift the throttle cable out of the throttle lever, making sure it clears the openings in the recess.
    • Continue to lift the throttle cable out of the throttle lever, making sure it clears the openings in the recess.
Sonuç
Craig Lloyd
8.983 İtibar
47 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
123 Üyeler
11.785 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 114
